we are generating RSFEC decoder IP we are providing required signal as input but we are not able to see output in modelsim
This is suggested to use the example design to run the simulation. You can generate the example design from the IP GUI. From the generated example design, there is a simulation_scripts folder. You can refer to the script over there to run the simulation.
\rs_ii_0_example_design\simulation_scripts
Regards -SK
Regards -SK
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
