FPGA Intellectual Property
6670 Discussions
Unable to run example design for 25G ethernet IP for startix device(1SGO85HN2F4312VG)
Abhinav_behl
Hello everyone,
I am trying to run simulation for the 25g Ethernet IP for startix fpga with fpga number 1SGO85HN2F4312VG. As per @https://www.intel.co.jp/content/www/jp/ja/programmable/documentation/gkr1505413442088.html#ezc1519265402640 I am running the simulation on modelsim. I am facing some issues in running the script.
The error message that I recieve is:
# do run_vsim.do
# ** Warning: (vlib-34) Library already exists at "work".
# basic_avl_tb_top
# C:\intelFPGA_pro\19.3\quartus
# ../ex_25g/sim
# false
# false
# bit_32
# -t fs
# work work_lib altera_ver lpm_ver sgate_ver altera_mf_ver altera_lnsim_ver fourteennm_ver fourteennm_ct1_ver altera lpm sgate altera_mf altera_lnsim fourteennm fourteennm_ct1
# Model Technology ModelSim - Intel FPGA Edition vmap 10.5c Lib Mapping Utility 2017.01 Jan 23 2017
# vmap work ./libraries/work/
# Modifying modelsim.ini
# vmap work_lib ./libraries/work/
# altera_common_sv_packages 1 altera_xcvr_native_s10_htile_1921 1 alt_e25s10_1930 1 altera_xcvr_atx_pll_s10_htile_191 1 altera_xcvr_reset_control_s10_191 1 altera_merlin_master_translator_191 1 altera_merlin_slave_translator_191 1 altera_merlin_master_agent_191 1 altera_merlin_slave_agent_191 1 altera_avalon_sc_fifo_191 1 altera_merlin_router_191 1 altera_merlin_traffic_limiter_191 1 alt_hiconnect_sc_fifo_191 1 altera_merlin_burst_adapter_191 1 altera_merlin_demultiplexer_191 1 altera_merlin_multiplexer_191 1 altera_mm_interconnect_191 1 alt_e25s10_avmm_fabric_multichannel_1930 1 ex_25g 1
# altera_common_sv_packages altera_xcvr_native_s10_htile_1921 alt_e25s10_1930 altera_xcvr_atx_pll_s10_htile_191 altera_xcvr_reset_control_s10_191 altera_merlin_master_translator_191 altera_merlin_slave_translator_191 altera_merlin_master_agent_191 altera_merlin_slave_agent_191 altera_avalon_sc_fifo_191 altera_merlin_router_191 altera_merlin_traffic_limiter_191 alt_hiconnect_sc_fifo_191 altera_merlin_burst_adapter_191 altera_merlin_demultiplexer_191 altera_merlin_multiplexer_191 altera_mm_interconnect_191 alt_e25s10_avmm_fabric_multichannel_1930 ex_25g
# ** Error: couldn't create error file for command: permission denied
# Error in macro ./../ex_25g/sim/mentor/msim_setup.tcl line 233
# couldn't create error file for command: permission denied
# while executing
# "error [FixExecError $msg]"
# (procedure "vmap" line 29)
# invoked from within
# "vmap $library ./libraries/$library/"
# ("foreach" body line 3)
# "foreach library $libraries {
# ensure_lib ./libraries/$library/
# vmap $library ./libraries/$library/
# lappend logical_libraries $library
The second method that I tried is to copy all the *.vhd,*.v,*.sv files in a seperate folder and compile them in modelsim in work library only (and of course changing the library in the internal files).
In this process, I face an error and mdoelsim exits with code 211 along with this info in vstf file:
# Current time Fri Apr 23 11:05:48 2021
# ModelSim - Intel FPGA Edition Stack Trace
# Program = vsim
# Id = "10.5c"
# Version = "2017.01"
# Date = "Jan 23 2017"
# Platform = win32pe
# Signature = 5e7f9b833961c34eb19f3225262e3a77
# 0 0x71046b2e: 'fdopen + 0x844' in 'c:\windows\system32\msvcr120.dll'
# 1 0x710b4aaf: 'vsnprintf_l + 0x81' in 'c:\windows\system32\msvcr120.dll'
# 2 0x710b4a29: 'vsnprintf + 0x16' in 'c:\windows\system32\msvcr120.dll'
# 3 0x01299c54: '<unknown (@0x1299c54)>'
# 4 0x004c13d2: '<unknown (@0x4c13d2)>'
# End of Stack Trace
Kindly help me.
Abhinav Behl
SengKok_L_Intel
What Quartus version that you are using? Could you please double-check if there is any permission (write enable) concern on your system?
Regards -SK Lim
Abhinav_behl
Hi @SengKok_L_Intel,
Thanks for your prompt reply,
I am using Quartus 19.3. And yes I have double-checked write permissions, I am running it on windows and every permission is given to all files.
Yesterday I also tried one more thing to open the ModelSim GUI and add files manually and then compile using compile auto-generate option in ModelSim.  In compilation also get errors. Apart from that when I try to run the simulation for top-level design, Modelsim exits with code 211 and the same message is printed in the .vstf file(to check vstf file I am told by ModelSim). For this step, I have attached the transcript file.
Please help me!
Abhinav Behl
Abhinav_behl
PS: sorry there was some mistakes in the compilation, even though I have solved all the compilation error I am still unable to simulate top-level design only (exiting with code 211). I am attaching the screenshot of the ModelSim window also.
SengKok_L_Intel
It seems like you are not using a compatible version of Modelsim Sim.
I have done a quick test, the 25G IP simulation is working fine with the Modelsim
Sim Intel FPGA edition 2019.2 for Quartus v19.3.
-SK
Abhinav_behl
I am also using the modelsim intel FPGA 2019.2 for Quartus v19.3, I am running using Cygwin command window but getting following error:
I have no idea how you are able to run the simulation for the 25G IP, can you share the details. The steps I am following are:
1. generate the example design from Quartus
2. GOTO directory/<example_testbench>
3. run "vsim -do run_vsim.do" command from cmd prompt.
I am also attaching permission of sim directory at which ModelSim is throwing error
Abhinav_behl
I was somehow managed to break the script into smaller scripts and was able to run the compilation, but after the compilation when I try to run the simulation I am still facing the error. I am attaching my transcript along in the attached section please review it.
SengKok_L_Intel
Hi
I was running at Linux by using v19.3 and using the same script as you, everything looks fine. Today, I tested it in my window system with v20.4 (v19.3 is not available in my setup), and it is working fine as well. Since v19.3 was an older version, I would suggest you move to v20.4 or later, and if you still encounter the problem, we can debug from there.
Regards -SK
Abhinav_behl
Hi @SengKok_L_Intel ,
As per your suggestion, I have Quartus 20.4 installed on my laptop. When I try to run the script from Cygwin I am getting the same issue. I am attaching the screenshot for it. I am using intel FPGA ModelSim version 2019.2
To remove these error I breakdown the script and compiled in ModelSim. I was able to run the "com" command (which is for compiling files in the correct order(as per the script)). But when I try to run the "elab" command I am getting the same error as with the previous versions. I am attaching the transcript for the same( after running "elab").
Let me know if you require any other files.
Kindly help me I am stuck with this problem for a very long.
Abhinav Behl
SengKok_L_Intel
Could you please try this:
  1. Open the Modelsim
  2. Change the directory to example_testbench
  3. Go to tool -> TCL -> execute macro -> run_vsim.do
Regards -SK
Abhinav_behl
I tried the steps facing the error, attaching the screenshot.
Abhinav behl
SengKok_L_Intel
The error message indicates there is a write access problem in your simulation folder. Perhaps you may try to run it in a different folder or another PC. From my window 10 PC, I did not encounter this problem, and this problem should not relate to the simulation script but your simulation directory writes permission.
Abhinav_behl
I tried on some other PC the simulation was up, but the test case is still not passing. I tried running simulations for both MAC+PCS+PMA and MAC+PCS. In both the testcases, I am waiting for RX alignment.  I have also attached the transcript for the MAC+PCS+PMA test case.
Kindly help!!
PS: In the IP generate section I have only selected mac statistics counters and simulation results are for single-channel design only.
Abhinav Behl
SengKok_L_Intel
Please let the simulation run for a longer time. It requires some time for Alignment Marker to lock.
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
