FPGA Intellectual Property
6673 Discussions
S-10 Transceiver IO Terminations
HBhat2
New Contributor II
I am using stratix 10 SoC dev kit with Transceivers with 10Gbps speed.
There, I want to use External termination for the transceiver receiver pins. As per the L tile user guide, we can set r_unused option in the native PHY.[Table 23. RX Analog PMA Settings Options]
I checked setting the same in Native PHY, the error message is listed saying that r_unused as invalid. What is the procedure to set external termination for receiver pins?
Also, I checked with "set_instance_assignment " commands & seeing no impact on these commands.
set_instance_assignment -name HSSI_PARAMETER "pma_rx_buf_term_sel= r_unused" -to AH45
set_instance_assignment -name HSSI_PARAMETER pma_rx_buf_term_sel= r_unused -to AL43
With Regards,
HPB
HBhat2
New Contributor II
Quick update.
 Quartus tool is ignoring the "set_instance_assignment " constraints in the QSF file.
"Warning(332145): Command "set_instance_assignment" found in SDC file is not a proper SDC command and is being ignored "
With regards,
HPB
Rahul_S_Intel1
Hi ,
 Can you please try on pin planner
HBhat2
New Contributor II
Thanks for the suggestion. I missed this option. Will try & update.
With Regards,
HPB
