FPGA Intellectual Property
6670 Discussions
S10 PCIE fail to create design example
ASiu0
Hi All,
System configure:
OS: Win10
QII: 19.3
FPGA: 1SG280HH1F55I1VG
DOC: UG20032, UG20053, UG20170 , AN811
Question:
I follow the "Create the design example" section of those UG but fail to create a design example. It report error when I press "Generate Example Design" in Platform Designer. Please provide some advice for fix the issue.
Information attached:
Qsys file
Copy of error message
Log file
Thx
Albert
SengKok_L_Intel
In order to better assist you, could you please share with us the PCIe *.ip file, so that I can get the exact same setting as yours and try to generate the example design. Thanks.
Regards -SK
ASiu0
Dear SK,
As attached.
Thx.
Albert,
SengKok_L_Intel
I don't observe the same error, the example design is able to generate in my system. Could you please refer to the attachment for the example design that you are looking for and see if this work for you?
Regards -SK
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
