FPGA Intellectual Property
6670 Discussions
Simple question on Cyclone 4 GX usage
I am trying to use the GX transceiver on the GX starter board.
I've used the Mega wizard to generate a sgmii pcs/pma function.
What I don't understand is how the GX pins connect to the sgmii module.
I have gxp_clk , // 125Mhz differential clock pin M7 LVDS
gxn_clk , // 125Mhz differential clock pin N7 LVDS
rxp_data , // 1.4-V PCML pin E2 GXB_RX1
rxn_data , // 1.4-V PCML pin E1 GXB_RX1
txp_data , // 1.4-V PCML pin C2 GxB_TX1
txn_data , // 1.4-V PCML pin C1 GxB_TX1
The mega wizard generated module has
.gxb_cal_blk_clk ( ),
.ref_clk ( ), // MDI interface ??
.txp ( ), // MDI interface ??
.rxp ( ), // MDI interface ??
So how does the 6 GX pins connect to the 4 ports on the sgmii module ?
Is there a specific instantiation of the GX ? How do I specify the GXB_1
transceiver ? Just by virtue of pin assignment ?
I've looked at the TSE design example & cannot find any example of the
hookup. TIA.
