FPGA Intellectual Property
6670 Discussions
Some trouble with HDMI RX ip core (Bitec IP core)
hi,guys
I have some trouble when I used HDMI 2.0 IP CORE on my own Arroa 10 board.
Nvidia GTX1060 is used HDMI 2.0 test signal source, connect to FPGA serdes pin through my own connect board. I can see pll is locked, and GXB is ready, and HDMI core is locked, but the trouble is vid_lock is always low.And HDMI RX core have aux_data, audio_data output but have no vedio_data(vid_data,vid_de,vid_h,vid_v) output.
But when I loopback TX&&RX, RX CORE can output all vedio_data successful,which tx is sent color bar generated by myself using HDMI_TX IP CORE .
Any idea what this could be? Thanks for any help!
Updata : I am confused whether have no HDCP KEY will cause this problem.
doese the HDMI IP free?
--- Quote Start ---
hi,guys
--- Quote End ---
Hey Tiber, have you managed to solve this? I am at the same situation.. Exactly as you described, PLL locked GXB locked, core locked and sees parallel data coming from GXB. But vid_lock is low and nothing comes out from the vid_ interface..
The reference design has some errors provided by Altera .
--- Quote Start ---
--- Quote End ---
In terms of which bit? If you could point me to a direction it would be very much appreciated!
--- Quote Start ---
--- Quote End ---
Hi there, I am trying to use the ATX Plls on the HDMI reference design. I have re-compiled the software to use the ATX configuration, however the TX PLLs are not getting locked.Any suggestions/information on this front?
--- Quote Start ---
--- Quote End ---
In case this may be useful to someone. I can post more details on request:
[list]
[*]It is not advisable to use ATX Plls for lower HDMI rates, this due to jitter performance restrictions of the ATX.
[*]The NIOS sw that comes with the reference design has got two cases, for fPLL and ATX-PLLs, however the case for the ATX has a bug: The re-calibration process does not distinguish fPLL/ATX cases, however the re-calibration process for each is slightly different.Hope it helps
[/list]
