FPGA Intellectual Property
6673 Discussions
Synchronous multiple ports fifo
Hi All
Is there any megafunction for multiple inputs and single output ports fifo based synchronized queue? OR Can anyone suggest other alternative ways?
No. That is something you will have to build yourself.
Thanks for your reply.
Can you help with this?
I have one module with one input port. But input put for this module can come from multiple other modules. I should take the input FIFO basis.
Then you will need to work out some way to arbitrate between the sources.
What rate are they all running at?
usually 100MHz
