FPGA Intellectual Property
公告
6673 讨论
System console giving up when running the command "TEST_PHYSERIAL_LOOPBACK 0 1G 1000"
Vamsi_21
新分销商 I
16,758 次查看
I have generated the design example for Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document.
https://www.intel.com/content/www/us/en/docs/programmable/683063/19-1-19-1/10m-100m-1g-10g-ethernet-design-example.html
While testing it on the hardware, I am getting the below error from system console.
“error: master_write_32: This transaction did not complete in 60 seconds. System console is giving up.
While executing
“master_write_32 sport_id $address $wdata”
(procedure “reg_write” line 7)
invoked from within
“reg_write $PHY_IP_BASE_ADDR $seq_control 0X111”
(procedure “SETPHY_SPEED_1G” line
invoked from within
“CONFIG_IPORT $speed_test”
(procedure “TEST_PHYSERIAL_LOOPBACK” line 10)
invoked from within
TEST_PHYSERIAL_LOOPBACK 0 1G 1000”
I have changed the USB blaster frequency to 16MHz,6MHz but still I am getting the issue.
Details:
Quartus used : Quartus prime 22.2
Board :Intel arria 10 GX development board
Device : 10AX115S2F45I1SG.
Below are the clock pin assignments
Name pin assigned
mm_clk 125Mhz BD24 clk_125
ref_clk_1g 125MHz N37 REFCLK_SMA (modified using clk controller).
ref_clk_10g 644.53125Mhz AA37 REFCLK_SFP
标签 (1)
0 项奖励
45 回复数
ZiYing_Intel
员工
7,001 次查看
Hi Vamsi_21,
Could you try enable NPDME option and try testing again on hardware?
zying
0 项奖励
Vamsi_21
新分销商 I
6,948 次查看
I have enabled NPDME option and generated the example design.
I have given the pin assignments as follows
NAME                     pin assigned
mm_clk                  BD24
ref_clk_10g           AN8 (modified using clock controller)
While testing on the hardware , i am getting the below error from system console.
error:TTK failed reading from PHY slave_2000, cannot enable TTK functionality for this PHY. Please verify the reconfig_clk is running and ensure this PHY is not stuck in reset.
error: open_service: Could not open service at /devices/10AX115H(1|2|3|4|4E3)|..@1#2-13/(link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_1/jtag_phy_0.jtag/master: Channel busy
while executing
"open_service master $port_id"
(procedure "reg_write" line 4)
invoked from within
"reg_write $PHY_IP_BASE_ADDR $seq_control 0x141"
(procedure "SETPHY_SPEED_10G" line
invoked from within
"SETPHY_SPEED_10G"
(procedure "CONFIG_1PORT" line 10)
invoked from within
"CONFIG_1PORT $speed_test"
(procedure "TEST_PHYSERIAL_LOOPBACK" line 10)
invoked from within
"TEST_PHYSERIAL_LOOPBACK 0 10G 1000"
Below i have attached the screenshot of the error.
0 项奖励
ZiYing_Intel
员工
6,992 次查看
Hi Vamsi_21,
Is there any update from you?
zying
0 项奖励
ZiYing_Intel
员工
6,910 次查看
Hi Vamsi_21,
For tranceiver phy, we don't use open service. You may refer link below https://community.intel.com/t5/FPGA-Wiki/Arria10-Transceiver-PHY-Basic-Design-Examples/ta-p/735196
There got a lot example designs inside the which may help you how to code in the system console.
zying
0 项奖励
Vamsi_21
新分销商 I
6,885 次查看
I have checked for different jtag clock frequencies (24MHz, 16 MHz, 6MHz) and the reconfig_clk is assigned properly
But in the system console iam  still getting the below error
error:"TTK failed reading from PHY slave_2000, cannot enable TTK functionality for this PHY. Please verify the reconfig_clk is running and ensure this PHY is not stuck in reset."
0 项奖励
ZiYing_Intel
员工
6,816 次查看
Hi Vamsi_21,
Please check whether the reconfiguration clock is available according to the prompt information, and check whether the reconfiguration interface is in reset.
zying
0 项奖励
Vamsi_21
新分销商 I
6,790 次查看
The design which i have generated is Low latency ethernet 10g mac intel fpga ip-- 10M/100M/1G/10G example design(Arria 10) by following the below document:
"In this design example i have generated , there is no reconfiguration clock and  no reconfiguration reset."
Below iam attaching the screenshot of the phy block from RTL viewer.
0 项奖励
ZiYing_Intel
员工
6,762 次查看
Hi Vamsi_21,
Could you try disable the NPDME option and try on hardware again?
zying
0 项奖励
Vamsi_21
新分销商 I
6,741 次查看
I have disabled the NPDME option and tested on hardware, it is still showing the error below:
While executing
invoked from within
invoked from within
invoked from within
TEST_PHYSERIAL_LOOPBACK 0 1G 1000”.
0 项奖励
ZiYing_Intel
员工
6,726 次查看
Hi Vamsi_21,
It seems like need the enable the NPDME options. We can narrow down the issue first. Give me some time to find out the possibility that can make the TTK fail reading fail occur. In the meantime, you also can check the connection.
0 项奖励
ZiYing_Intel
员工
6,652 次查看
Hi Vamsi_21,
I just get to know that the EyeQ is no longer supported in A10 devices. It seems to be due to some issue with the EyeQ result. Please avoid using the EyeQ. Do you use the EyeQ?
zying
0 项奖励
Vamsi_21
新分销商 I
6,598 次查看
Hi, I am not using EyeQ,
I am using signal tap logic analyzer tool.
0 项奖励
ZiYing_Intel
员工
6,520 次查看
Hi Vamsi_21,
Can you share your .qar file? So that I can try debug the issue from my side.
zying
0 项奖励
Vamsi_21
新分销商 I
6,454 次查看
Hi,        Below I am sharing the .qar file
0 项奖励
ZiYing_Intel
员工
6,474 次查看
Hi Vamsi_21,
Can we try connect the reconfiguration clock and reconfiguration reset ?
zying
0 项奖励
Vamsi_21
新分销商 I
6,451 次查看
Hi,        In the example design which i generated there is no reconfiguration clock and reconfiguration reset.        Below i am sharing the screenshot of phy from RTL viewer.
0 项奖励
ZiYing_Intel
员工
6,365 次查看
Hi Vamsi_21,
I don't found any .tcl file inside the .qar file that your share? Please share the .qar file with the .tcl file inside it. So that I can debug the same issue from my side.
zying
0 项奖励
Vamsi_21
新分销商 I
6,338 次查看
I have added the .tcl file and I am sharing the .qar file
0 项奖励
ZiYing_Intel
员工
6,338 次查看
Hi Vamsi_21,
Can you try using another Quartus Prime Pro version 22.3? I don't see the error on Quartus 22.3 but I am using different opn.
zying
0 项奖励
Vamsi_21
新分销商 I
6,307 次查看
I have tried with Quartus Prime Pro version 22.2 , can u try with the same version of Quartus prime pro version.
0 项奖励
回复
