Can we take fourier transform of the image by using ALTERA IP core. This core take fft of vector. So, I cannot use this core for image. Is there any solution.
Mert Ege
As I understand it, you have some inquiries related to the FFT IP. Generally the FFT IP work with a packet of data. Sorry as I am not very clear on what you mean by image vs vector in your initial description. Would you mind to further elaborate on this? Thank you very much.
I want to take fft of image (2-D Vector) on FPGA. Therefore, I want to use FFT IP of ALTERA. I tried matlab code of IP core but I cannot take fourier transform of image since it does not admit 2-D vector. Would you explain further "packet of data" ? Maybe, it can be solution for my problem.
Mert Ege
For more complete information about compiler optimizations, see our Optimization Notice.
