Hello Altera Forums,
I am trying to get the Simple Socket Server working on an Arria V starter kit. I have created a Nios system to accomplish this. Here is a screenshot of the system: https://i.imgur.com/AZOlZyc.png I have connected the Nios system to the appropriate pins, and when I run the Simple Socket Server (RGMII), I get this response:InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Can't read the MAC address from your board. We will assign you
a MAC address.
Please enter your 9-digit serial number. This is printed on a
label under your Nios dev. board. The first 3 digits of the
label are ASJ and the serial number follows this.
-->Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
123456789
123456789
Your Ethernet MAC address is 00:07:ed:ff:cd:15
prepped 1 interface, initializing...
INFO : TSE MAC 0 found at address 0x08202000
INFO : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group
INFO : PHY - Automatically mapped to tse_mac_device
INFO : PHY - Restart Auto-Negotiation, checking PHY link...
INFO : PHY - Auto-Negotiation PASSED
MARVELL : Mode changed to RGMII/Modified MII to Copper mode
MARVELL : Enable RGMII Timing Control
MARVELL : PHY reset
INFO : PHY - Checking link...
INFO : PHY - Link not yet established, restart auto-negotiation...
INFO : PHY - Link established
INFO : PHY - Speed = 1000, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x0400020b
RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 142.104.60.71
DHCP timed out, going back to default IP address(es)
Simple Socket Server starting up
Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
When I try to ping, I get no connection. To debug, I connected signal tap to the RX[3..0] and TX[3..0] signals. I am seeing signal on the RX bus, but there is no data on the TX bus. The tx_enable pin is also never asserted. This is likely why the Simple Socket Server can't connect to the DHCP, but I can't figure out why there is no data on the TX bus. Help me alteraforum, you're my only hope!
链接已复制
1 回复
If anyone comes across this when looking for solutions, I managed to fix it by constraining the timing. I used the board update portal example provided with the Arria V starter kit (on the CD) as a starting point and modified it to fit with my design.
I am now able to connect to the DHCP and get assigned an IP address. I can ping successfully, but I get a 60% packet loss I've included the SDC files that solved my timing issues here in case anyone else finds them useful. If you have any insights into why I'm losing so many packets, I would be grateful.
