FPGA Intellectual Property
6673 Discussions
Triple-Speed register configuration
Hi all. I'm using tse single port rgmii arria v gx project (AN647) and configure command_config register fields via tcl scripts. Is there a possibility to configure this register in project, to avoid doing this every time after programing FPGA?
Thanks for your time.
Hi,Andrey13! Can you tell me how to configure register with tcl scripts? The user guide says:
"At the minimum, you must
configure the following functions:
• Primary MAC address (mac_0/mac_1)
• Enable transmit and receive paths (TX_ENA and RX_ENA bits in the
command_config register)"
But I don't know how to write these registers.
Anything can help!
Best wishes!
Hi, siepha. You must connect your board with JTAG interface. Then go to Qsys -> Tools -> System Console. Set the root directory with your tcl scripts "cd C:/.../sc_tcl". Then run config.tcl "source config.tcl". Good luck!
