FPGA Intellectual Property
6670 Discussions
Trying to erase a sector in the cfm. However, in simulation, I never get a busy signal. help
NBRUM
// Address values for the control and status register (csr) parameter FLASH_STATUS_REG_ADDR = 1'b0, // only for read operations parameter FLASH_CONTROL_REG_ADDR = 1'b1, // for read and write operations // Write protection parameters // Write protection 1'b1 for enabled and 1'b0 for disabled. parameter SECTOR_1_WRT_PROTECTION_INDICE = 23, // writedata indice that needs to change parameter SECTOR_2_WRT_PROTECTION_INDICE = 24, // writedata indice that needs to change parameter SECTOR_3_WRT_PROTECTION_INDICE = 25, // writedata indice that needs to change parameter SECTOR_4_WRT_PROTECTION_INDICE = 26, // writedata indice that needs to change parameter SECTOR_5_WRT_PROTECTION_INDICE = 27, // writedata indice that needs to change parameter ENABLE_WRT_PROTECTION = 1'b1, // enables the write protection for a section parameter DISABLE_WRT_PROTECTION = 1'b0, // disables the write protection for a section parameter READ = 1'b1 , parameter WRITE = 1'b1 // Erase on-chip flash operation parameter ERASE_INDICE_START = 20, // writedata indice start for writedata parameter ERASE_INDICE_END = 22, // writedata indice end for writedata parameter SECTOR_1 = 3'b001, // writedata value to erase sector 1 parameter SECTOR_2 = 3'b010, // writedata value to erase sector 2 parameter SECTOR_3 = 3'b011, // writedata value to erase sector 3 parameter SECTOR_4 = 3'b100, // writedata value to erase sector 4 parameter SECTOR_5 = 3'b101, // writedata value to erase sector 5 onchip_flash_csr_writedata[SECTOR_3_WRT_PROTECTION_INDICE] = DISABLE_WRT_PROTECTION; onchip_flash_csr_writedata[ERASE_INDICE_END : ERASE_INDICE_START] = SECTOR_3; onchip_flash_csr_address = LASH_CONTROL_REG_ADDR; onchip_flash_csr_write = WRITE;
My code above is part of my module and should yield a busy erase signal but does not. Any advice would be great. I am using Questa. For more context. I am trying to design an module for manual RSU because I can not use Nios.
JohnT_Intel
We do not support simulation on On Chip Flash IP. You can only use the On Chip Flash IP with preloaded data. Other function is not supported
NBRUM
It was due to the timing. I had an incorrect clock. Once I fixed that the ip core simulated fine.
JohnT_Intel
I am glad that the issue is due to timing where using incorrect clock.
