FPGA Intellectual Property
6670 Discussions
Unable to find SVSfftmodel needed by Variable Streaming FFT Matlab mode
I am trying to use the Matlab model generated by the variable streaming FFT megacore, and it wants to use the SVSfftmodel function which it thinks should exist in C:\altera\91\ip\altera\fft\lib\ip_toolbench sub-folder, but no matlab models exist there.
Any suggestions will be greatly appreciated.
It's not m-file, it is SVSfftmodel.mexw32 file.
And Altera Support Solution:
Title
??? Undefined function or method 'SVSfftmodel' for input arguments of type 'double'.
Description
You may see this error when you use a 64-bit Matlab to simulate the FFT MegaCore’s Matlab model <variation name>_model.m. This FFT Matlab model is currently supported in 32-bit Matlab only where 64-bit Matlab is not supported.
