FPGA Intellectual Property
6673 Discussions
Using Arria 10 Transceiver native PHY IP core
Hi!
I recently bought Arria 10 SoC dev kit. I try to transfer data via SFP+ and loopback through fiber cable, with data rate 1.25Gbps. I use Arria 10 Transceiver PHY IP to perform this task.
I read and follow the steps in the book "Arria 10 Transceiver PHY User Guide".
In my design included : Transceiver native PHY IP core; Transceiver native PHY Reset Controller; ATX PLL.
I have connected the PHY IP to the PLL IP Core and Reset Controller like in the User Guide.
I used preset "Serial Rapid IO 1.25Gbps" to set the parameters for the Transceiver native PHY IP core.
I get the optimal PMA settings for the transceiver for the best bit error rate and reliability, then i edit the file .qsf according to the parameters received as transceiver toolkit, and then recompile my project. But I get unwanted results, the data I receive is sometimes unstable.
Can you help me solve this problem ?
Does anyone know about this problem ? please, consultants help me !
In my design i use : Transceiver native PHY IP core; Transceiver native PHY Reset Controller; ATX PLL.
At first i thought the problem was Analog Parameter Settings. But I used Transceiver Toolkit to get the optimal PMA settings for the transceiver for the best bit error rate and reliability.
After many compiling i think my problem is something not quite right in my PCS or design in the core or in the transition between the two.
Here is my design:
