This is obviously a beginner question, but I am getting some odd behavior from a tri-state mux, and was just wondering if someone could check the correctness of this code: inout [7:0] bus; wire bus_oe; wire select; wire [7:0] data1; wire [7:0] data2; assign bus = bus_oe ? (select ? data1:data2): 8'hZZ; The behavior sought is: if 'bus_oe' is false then 'bus' is HiZ, otherwise if 'select' is true connect 'bus' to 'data1', if false connect 'bus' to 'data2'. I am using Quartus II 10.0 with a cyclone II chip. Thanks, WahranLink Copied
This should be OK.
how odd is it?
