FPGA Intellectual Property
6664 Discussions
What are Simulink toolboxes needed to run Cholesky Solver w/ Altera Advanced DSP
When I compiled an example of Altera Adv DSP builder: Cholesky solver, there are several fixed point license errors. After ran Simulink Model Advisor, there are the following errors
check for non-continuous signals driving derivative ports Could not compile model cholesky_solver_sc.
file:///C:/altera/12.0/quartus/dspba/Examples/ReferenceDesigns/CholeskySolver/slprj/modeladvisor/cholesky__solver__sc/task_failed.png check model, local libraries, and referenced models for known upgrade issues requiring compile time informationError occurred during model compile.
Error due to multiple causes.
file:///C:/altera/12.0/quartus/dspba/Examples/ReferenceDesigns/CholeskySolver/slprj/modeladvisor/cholesky__solver__sc/task_failed.png check for partial structure parameter usage with bus signalsError occurred during model compile.
file:///C:/altera/12.0/quartus/dspba/Examples/ReferenceDesigns/CholeskySolver/slprj/modeladvisor/cholesky__solver__sc/task_failed.png check for proper bus usageError occurred during model compile.
file:///C:/altera/12.0/quartus/dspba/Examples/ReferenceDesigns/CholeskySolver/slprj/modeladvisor/cholesky__solver__sc/task_failed.png check for calls to sldatatypeandscale()Error occurred during model compile.
file:///C:/altera/12.0/quartus/dspba/Examples/ReferenceDesigns/CholeskySolver/slprj/modeladvisor/cholesky__solver__sc/task_failed.png check for potentially delayed function-call subsystem return valuesError occurred during model compile.
file:///C:/altera/12.0/quartus/dspba/Examples/ReferenceDesigns/CholeskySolver/slprj/modeladvisor/cholesky__solver__sc/task_failed.png identify block output signals with continuous sample time and non-floating point data typeError occurred during model compile.
file:///C:/altera/12.0/quartus/dspba/Examples/ReferenceDesigns/CholeskySolver/slprj/modeladvisor/cholesky__solver__sc/task_failed.png check for proper merge block usageError occurred during model compile.
file:///C:/altera/12.0/quartus/dspba/Examples/ReferenceDesigns/CholeskySolver/slprj/modeladvisor/cholesky__solver__sc/task_failed.png check consistency of initialization parameters for outport and merge blocksError occurred during model compile.
file:///C:/altera/12.0/quartus/dspba/Examples/ReferenceDesigns/CholeskySolver/slprj/modeladvisor/cholesky__solver__sc/task_failed.png check data store block sample times for modeling errorsError occurred during model compile.
file:///C:/altera/12.0/quartus/dspba/Examples/ReferenceDesigns/CholeskySolver/slprj/modeladvisor/cholesky__solver__sc/task_failed.png check for potential ordering issues involving data store accessError occurred during model compile.
Could someone help to point out what toolbox needed to run this example?
Thanks in advance,
Jiuxiang
For the Altera Advanced DSP Builder Blockset you need the Simulink Fixed Point Blockset, see here:
http://www.altera.com/support/ip/dsp/ips-dsp-version.html (http://www.altera.com/support/ip/dsp/ips-dsp-version.html)
Schmalish
Thanks a lot.
Jiuxiang
