FPGA Intellectual Property
6669 Discussions
Why does the E-Tile transceiver PHY IP get zero eye height in some cases?
BarryT
We have tested many devices and only a few environments where the Eye Height value is 0 for 2.5G read and the data is normally sent and received. This causes a lot of problems.
So, I would like to ask what causes this phenomenon. Is there any solution?
ZiYing_Intel
Hi BarryT,
May I know that your TTK using which Quartus version?
Zi Ying
BarryT
Hi Zi Ying,
it's Quartus Prime Version 20.1.0.
But we don't use TTK to get the eye height, we use attribute code to get it.
BarryT
ZiYing_Intel
Hi BarryT,
Can you try to use TTK to see eye viewer still got 0 height?
Zi Ying
ZiYing_Intel
Hi BarryT,
Is there any update from your side?
Zi Ying
BarryT
Hi Zi Ying,
      I do not have the conditions to use TTK to get eye height, maybe I need to think about other ways.
      Thanks for your help.
BarryT
