FPGA Intellectual Property
6670 Discussions
Why lpm_mult can not be synthesized?
Hello, everyone
I recently have tried to use Lpm_Mult to accomplish a complex multiplication.
But the Analysis & Synthesis part in the Compile Design can not be processed.
There are two Errors:
(1) Text Design File syntax error: Text Design File contains '(' where ASSERT, CONSTANT, DEFINE ,DESIGN,
FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected
(2) Text Design File syntax error: Text Design File contains IF where ASSERT, CONSTANT, DEFINE ,DESIGN,
This problem has troubled me for quite a long time, please help me. Thanks a lot
For a helpful answer, minimal information about the implemented design are necessary.
Ok, in the design, Algorithm, I want to accompolish a complex number multiplication.
The real and imaginary parts of the complex number come from NumOneReg and NumTwoReg.
When StartCacu gets high, the caculation starts.
Then, four LpmMult entity accomplish four multiplication needed.
After that comes two addition.
In Quartus ii, when I tried the Analysis & Synthesis, the two syntax errors come out, which are
Please give me some advices. Thank you
Below is the code.
entity Algorithm is
port(
-- input
Clk : in std_logic;
Reset : in std_logic;
NumOneReg : in std_logic_vector(31 downto 0);
NumTwoReg : in std_logic_vector(31 downto 0);
StartCacu : in std_logic;
-- output
CacuReg : out std_logic_vector(31 downto 0);
CacuDone : out std_logic
end entity;
architecture Addition of Algorithm is
type CacuState is (Idle, Load, Multi, AddAll,CacuEnd );
signal CacuFSM : CacuState;
signal A_Real : std_logic_vector(7 downto 0);
signal A_Imagine : std_logic_vector(7 downto 0);
signal B_Real : std_logic_vector(7 downto 0);
signal B_Imagine : std_logic_vector(7 downto 0);
signal RealOne : std_logic_vector(15 downto 0);
signal RealTwo : std_logic_vector(15 downto 0);
signal ImagineOne : std_logic_vector(15 downto 0);
signal ImagineTwo : std_logic_vector(15 downto 0);
signal RealOneMid : std_logic_vector(15 downto 0);
signal RealTwoMid : std_logic_vector(15 downto 0);
signal ImagineOneMid : std_logic_vector(15 downto 0);
signal ImagineTwoMid : std_logic_vector(15 downto 0);
signal ResultReal : std_logic_vector(15 downto 0);
signal ResultImagine : std_logic_vector(15 downto 0);
signal EnMutiClk : std_logic;
signal MultiCnt : integer;
signal EnAddClk : std_logic;
signal AddCnt : integer;
constant MutiConstant : integer := 1;
constant AddConstant : integer := 1;
component LpmMult
port
clock : IN STD_LOGIC ;
clken : IN STD_LOGIC ;
dataa : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
datab : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR (15 DOWNTO 0)
end component;
component LpmAddSub
port
add_sub : IN STD_LOGIC ;
dataa : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
datab : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
end component;
begin
process(Reset, Clk)
begin
if Reset = '0'then
CacuDone <= '0';
CacuReg <= (others => '0');
A_Real <= (others => '0');
A_Imagine <= (others => '0');
B_Real <= (others => '0');
RealOne <= (others => '0');
RealTwo <= (others => '0');
ImagineOne <= (others => '0');
ImagineTwo <= (others => '0');
CacuFSM <= Idle;
EnMutiClk <= '0';
EnAddClk <= '0';
MultiCnt <= 0;
AddCnt <= 0;
elsif rising_edge(Clk)then
CacuDone <= '0';
case CacuFSM is
when Idle =>
if StartCacu = '1'then
CacuFSM <= Load;
end if;-- StartCacu
EnMutiClk <= '0';
EnAddClk <= '0';
when Load =>
A_Real <= NumOneReg(15 downto 8);
A_Imagine <= NumOneReg(7 downto 0);
B_Real <= NumTwoReg(15 downto 8);
B_Imagine <= NumTwoReg(7 downto 0);
EnMutiClk <= '1';
MultiCnt <= 0;
AddCnt <= 0;
CacuFSM <= Multi;
when Multi =>
if MultiCnt = MutiConstant then
RealOne <= RealOneMid;
RealTwo <= RealTwoMid;
ImagineOne <= ImagineOneMid;
ImagineTwo <= ImagineTwoMid;
EnMutiClk <= '0';
EnAddClk <= '1';
MultiCnt <= 0;
CacuFSM <= AddAll;
else
MultiCnt <= MultiCnt + 1;
end if;
when AddAll =>
if AddCnt = AddConstant then
CacuReg(31 downto 16) <= ResultReal;
CacuReg(15 downto 0) <= ResultImagine;
AddCnt <= 0;
EnAddClk <= '0';
CacuFSM <= CacuEnd;
else
AddCnt <= AddCnt + 1;
end if;
when CacuEnd =>
CacuDone <= '1';
CacuFSM <= Idle;
when others =>
end case;
end if; -- Reset
end process;
-- Multiplication
A_Real_and_B_Real : LpmMult PORT MAP (
clock => Clk,
clken => EnMutiClk,
dataa => A_Real,
datab => B_Real,
result => RealOneMid
A_Imagine_and_B_Imagine : LpmMult PORT MAP (
clock => Clk,
clken => EnMutiClk,
dataa => A_Imagine,
datab => B_Imagine,
result => RealTwoMid
A_Real_and_B_Imagine : LpmMult PORT MAP (
clock => Clk,
clken => EnMutiClk,
dataa => A_Real,
datab => B_Imagine,
result => ImagineOneMid
A_Imagine_and_B_Real : LpmMult PORT MAP (
clock => Clk,
clken => EnMutiClk,
dataa => A_Imagine,
datab => B_Real,
result => ImagineTwoMid
-- Addition
RealPart : LpmAddSub PORT MAP (
add_sub => '0',
clock => Clk,
clken => EnAddClk,
dataa => RealOne,
datab => RealTwo,
result => ResultReal
ImaginePart : LpmAddSub PORT MAP (
add_sub => '1',
clock => Clk,
clken => EnAddClk,
dataa => ImagineOne,
datab => ImagineTwo,
result => ResultImagine
end Addition;
try first of all to correct your syntax errors at:
if Reset = '0'then
should be
if Reset = '0' then
and do the same for all others. I don't think it has any thing to do with your post title.
