FPGA Intellectual Property
6670 Discussions
altera_onchip_flash
The submodule "altera_onchip_flash_avmm_data_controller" in this IP has some problem.
WRITE_STATE, this FSM will unexpectedly been hold when I continues write data to flash.
It will cause status stock in write busy. csr_readdata[1:0] will equal to 2'b10 which means BUSY_WRITE for a long time.
It might be something wrong with its' state machine.
I guess the register "write_count " is overflow, so I replace "write_count != 0" to "write_count > 0" .
Finally, it work out.
// Avalon_MM data interface fsm - communicate between Avalon_MM and Flash IP (Write Operation)
always @ (posedge clock) begin
if (~reset_n_w) begin
write_state <= WRITE_STATE_IDLE;
write_wait <= 0;
end
else begin
case (write_state)
WRITE_STATE_IDLE: begin
// reset all register
write_count <= 0;
write_timeout <= 1'b0;
enable_drclk_neg_pos_write_reg <= 0;
// check command
if (avmm_write) begin
if (~valid_csr_erase && ~is_erase_busy && ~is_read_busy) begin
write_wait <= 1;
// address legality check
if (is_addr_writable && is_valid_write_burst_count) begin
write_state <= WRITE_STATE_WRITE;
write_count <= DATA_WIDTH[5:0];
end
else begin
write_state <= WRITE_STATE_ERROR;
write_wait <= 0;
write_count <= 2;
end
end
end
end
WRITE_STATE_WRITE: begin
if (write_count > 0) begin//(write_count != 0) begin
write_drclk_en <= 1;
write_count <= write_count - 16'd1;
end
else begin
enable_drclk_neg_pos_write_reg <= 1;
write_drclk_en <= 0;
write_count <= FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX[15:0];
write_state <= WRITE_STATE_WAIT_BUSY;
end
end
WRITE_STATE_WAIT_BUSY: begin
if (flash_busy_reg) begin
write_count <= FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX[15:0];
write_state <= WRITE_STATE_WAIT_DONE;
end
else begin
if (write_count > 0) //(write_count != 0)
else begin
write_timeout <= 1'b1;
write_count <= FLASH_RESET_CYCLE_MAX_INDEX[15:0];
write_state <= WRITE_STATE_RESET;
end
end
end
WRITE_STATE_WAIT_DONE: begin
if (~flash_busy) begin
write_count <= FLASH_RESET_CYCLE_MAX_INDEX[5:0];
end
else begin
end
else begin
end
end
end
WRITE_STATE_RESET: begin
if (write_timeout) begin
csr_status_w_pass <= 1'b0;
end
else begin
csr_status_w_pass <= flash_sp_pass_reg;
end
if (write_count == 1) begin
write_wait <= 0;
end
end
else begin
end
end
WRITE_STATE_ERROR: begin
csr_status_w_pass <= 0;
write_wait <= 0;
end
end
else begin
end
end
default: begin
end
endcase
end
end
i replace all (write_count != 0) to (write_count > 0) in the WRITE_STATE FSM
end
else begin
end
end
I do some simulation. Two type coding looks totally different on technology map.
A type coding : "write_count != 0"
The FSM will fail if there is a glitch on clock.
B type coding : "write_count > 0"
The FSM will be fine if there is a glitch on clock.
By the way, my device is MAX10. I think MAX10's clock may have some problem.
Where can i share these simulation file?
Can anyone teach me why these two type coding make so much different on the end?
Thanks a lot.
I think you saw success with the modification you made because the actual problem is a timing error. You must have gotten lucky on the new compile to have it not lock up the internal logic. The real issue is a timing bug with the busy signal. The fix I put in place for the 14.1 standard release code was to change line 446 from:
always @ (negedge reset_n or negedge is_busy or posedge flash_osc) begin
to
always @ (negedge reset_n or negedge is_busy or posedge clock) begin
The problem was that the flash_busy_reg signal needed to get latched in the clock domain, not the flash_osc domain. When I made this change it resolved all the timing errors and also worked flawlessly. After I reported this to Altera they informed me that there is a patch to install on 14.1 that also fixes this.
