FPGA Intellectual Property
altgxb ip
I have problems to re-configure the data rate of transceiver receiver with altgxb_reconfig megafuntion. What I wanted to do exactly is a data rate switch using clock dividers (change receptor from 2 to 1 Gbyte)s . In the page 2-225/6 of the document Stratix II GX device handbook, volume 2, can find the steps to continuing, but I get lost in the 6th. Did someone may detail to me by little more which are the steps to following?
File an SR on the Altera Support WEB page.
Make sure you list the current version of the tools you are using and the target part.
