FPGA Intellectual Property
6659 ディスカッション
altlvds_rx
XQSHEN
初心者
1,543件の閲覧回数
How to make sure data is aligned with fclk when using altlvds_rx ip?
0 件の賞賛
1 解決策
Ash_R_Intel
従業員
1,307件の閲覧回数
Please refer the ALTLVDS user guide section 1.3.2: https://www.intel.com/content/www/us/en/docs/programmable/683062/17-1/lvds-serdes-transmitter-receiver-ip-36681.html
In external PLL mode rx_coreclock can be used in the fabric logic to further process the data. In this mode, rx_coreclock is same as the rx_syncclock which is an input to the ALTLVDS_RX.
rx_syncclock is used to receive the parallel data.
元の投稿で解決策を見る
5 返答(返信)
Ash_R_Intel
従業員
1,436件の閲覧回数
Can you please tell which device IP are you using?
XQSHEN
初心者
1,427件の閲覧回数
Ash_R_Intel
従業員
1,361件の閲覧回数
The ALTLVDS IP has rx_coreclock signal. You can connect the fabric clock to it.
XQSHEN
初心者
1,334件の閲覧回数
where is this signal, rx_coreclock ?
Ash_R_Intel
従業員
1,308件の閲覧回数
返信
