FPGA Intellectual Property
6670 Discussions
aud_ws_in signal in SDI audio extractor
Hi
The aud_ws_in signal in SDI audio extractor is used as a reference word select signal to align the serial outputs of multiple audio extractors.
(please see SDI use guide for the original description).
So, I expect to see aligned serial audio data if I connect a clock of 48KHz to the aud_ws_in of several audio extractors.
(My bit clock for the audio is 3.072MHz)
However, when I really do this, I don't think I have seen seen aligned serial audio data from signaltapII. Please see the attached siganltapII waveform.
The embedded audio data in SDI are all 1KHz tone from a test pattern generator. So their serial data should be the same. All I need is to align data between multiple audio extractors. Should I add FIFO to do this?
Does anyone have some suggestions about my question? Thanks.
Hello, YUFU0511!
Did You find out how to solve that problem?
Hi, Aphraton
I eventually find the signal "aud_ws_in" can do the work for me.
You may see the SDI user guide to understand how to use it.
--- Quote Start ---
Hi, Aphraton
--- Quote End ---
Yes, I understand how to use signal "aud_ws_in".
But You reported, that You had problems - output data not being aligned as seen in Your SignalTap screenshot.
How did You solve output data not being aligned?
