FPGA Intellectual Property
6669 Discussions
cascaded IFFT WITH FFT
hello,
I try to cascad an IFFT(v2.2.1) with an FFT(v2.2.1) in a OFDM design for channel estimation. I have simulated the entire chain with MODELSIM and all data given by the FFT is the same such as my SCILAB simulation chain. But when I integrate my design on FPGA (here STRATIX S80), the data obtained by the FFT output (observe with SignalTap) are not the same such as simulated, the design lost 8 samples. I have verify the signal for FFT CTRL, but i don't find where is the problem? if someone can help me!
thanks
What do you mean by the design lost 8 samples ? You entered a sequence of N samples and on the ouput you have a sequence of N-8 samples ?
Jérôme
