FPGA Intellectual Property
6670 Discussions
configure the triple speed ethernet register with verilog
Hello! I am using TSE(triple speed ethernet) ip core to implement communication bewteen my pc and the FPGA board(cyclone IV). But I don't know how to configure the TSE register with verilog. I do read some information from the user guide. For example, here are from the user guide:
Base registers to configure the MAC function. At the minimum, you must
configure the following functions:
• Primary MAC address (mac_0/mac_1)
• Enable transmit and receive paths (TX_ENA and RX_ENA bits in the
command_config register)
But I don't know how to realize this configuration in my quartus II project with verilog.
Anything can be help!
Best wishes!
Register & Go through the “Implementing the Triple-Speed Ethernet MegaCore Function” training material for the detail stepwise solution,
https://www.altera.com/support/training/course/otse1116p2.html
Also, refer the design example & Intel FPGA Triple-Speed Ethernet IP Core User Guide & try at your end.
https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-tse-sgdma.html
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ethernet.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
Intel Customer Support – Engineering
(Under Contract to Intel)
