FPGA Intellectual Property
6672 Discussions
data transfer between pcie mm-dma and on chip fifo
clair
I searched a similar question. It is just transfer data between PCIe MM-dma and on-chip fifo, the demo altera gives is all about on chip mem.
Needs help with the design,! thanks !
https://forums.intel.com/s/question/0D50P00003yyTWDSA2/pcie-mmdma-has-no-option-for-going-tofrom-fifo
Nathan_R_Intel
Hie, your question is not clear enough. Could you help clarify it. Are you looking for a reference design that supports ​DMA write/read from/to fifo? If yes, then Intel-PSG currently don't have such a reference design. Currently, the reference design available only allows DMA read/write from/to on chip memory.
Do let me know if your question is unanswered and you need further clarification
