FPGA Intellectual Property
6670 Discussions
how to expand the pcie rx completion buffer size?
vincent_lin
As the documetion says, it is critical to monitor the available RX completion buffer entries to prevent overflow by excessive Non-Posted requests. However, the current RX completion buffer in our IP core has limited capacity - providing only 1,444 credits for Completion Data (CplD), which translates to approximately 1.4μs of buffer time at 500MHz clock frequency with a 512-bit data width. This constraint significantly impacts our ability to maintain optimal outstanding request performance. Could you suggest potential methods to increase the throughput of Non-Posted requests within the current system constraints?
Wincent_Altera
Hi ,
May I know which document that you are referring to ?
What is the device/design ? just to ensure that we are looking at the same page.
Wei Chuan
vincent_lin
    The document is  P-Tile Avalon Streaming Intel FPGA IP for PCI Express User Guide, and our device is AGFB023R25A2E2V,
 the suggestion of How to send NP Requestes as follow,
the completion buffer size as follow
Wincent_Altera
I do a deep check on that, unfortunately NP transactions mentioned in the user guide is the maximum.
If this features is strictly needed and you have strong business justification, I suggest to talk to your local Distributor FAE to file a feature request ticket.
Please accept my apology for cannot help so much on this.
Wincent_Altera
Wincent_Altera
I wish to follow up with you about this forum case.
Do you have any further questions on this matter ? Else do I have your permission to close this IPS ticket ?
Wincent_Altera
vincent_lin
No further questions. You may close this case now.
