FPGA Intellectual Property
hps ddr3
FPGA1
hi
In HPS, I connect an Avalon-mm-bridge host to f2h-Axi-slave, and export the slave of Avalon-mm bridge from the machine. Can I read and write DDR3 on the HPS side directly?
BrusC_Intel
Hello, FPGA1.
Thank you for posting in the Intel Community Support forum.
I will route your thread to a section for similar issues/questions so it can get answered as soon as possible.
Bruce C.
EBERLAZARE_I_Intel
It is recommended that you do all interconnect and bring it inside Platform Designer than exporting it out. If you are trying to access the DDR3 of the HPS , you will need a EMIF IP for the HPS and set the settings a per spec of your DDR connect it to the HPS.
EBERLAZARE_I_Intel
Any followup from your side?
FPGA1
Sorry, I just logged in today
I'm a little bit delayed now. I didn't continue with it
But I want to ask, can't Avalon mm bridge be imported from SoC system as data input on FPGA side? I just searched the EMIF IP, but I didn't find it. Can I explain this in detail
FPGA1
Spoiler
 I just went to cut a picture for you,We are eager to solve this problem ,thanks
