FPGA Intellectual Property
6670 Discussions
import data into Nios
Could anyone tell me that what is the fastest way to import data to Nios?
For instance, I have a verilog module and the output is
output [7:0] dout;
output source_valid;
with a clock rate of 25MHz. Is there any way to import these data into Nios system without loss? Apparently the pio itself can not fulfill this task.
hi guy!!!
you need to put a avalon data bus......this solve your problem
avalon mm slave i guess(i cant remenber)
cheers
Franz Wagner
--- Quote Start ---
hi guy!!!
cheers
Franz Wagner
--- Quote End ---
Hi Franz, Thanks for your quick reply!
But can you give a for instance, like a sopc figure? I do not quite understand how to put an avalon data bus...
yess.....
at sopc builder ....avalom mm slave ....i guess
good luck
Franz Wagner
Well, I did not quite get that... I can not find this component in sopc builder. whence you have time can you please explain more details for me?
i did that but i cant remenber...... i create a component i guess (or get in internet)
try to use spi slave to avalon mm
http://www.alterawiki.com/wiki/spi_slave_to_avalon_mm
cheers
Franz Wagner
