FPGA Intellectual Property
6666 Discussions
mem_reset_n always is low from DDR3 hard controller
EBoln
i have ArriaV, DDR3 chips, but after deassert global and soft resets mem_reset_n stay is low. Soft reset generate after 1000 tick on 100MHz clk
What else can affect this signal?
AdzimZM_Intel
Hi Sir,
I'm Adzim. Thanks for using Intel Community.
According to the KDB here, it's looks like the global and soft resets can only trigger the mem_reset_n signal.
Are you using the example design in your simulation?
If not, can you simulate your IP with the example design?
Which Quartus software that you used?
Adzim
EBoln
I am using 18.1.1 and 20.1 standard edition
AdzimZM_Intel
Have you try to simulate your IP with the example design in your simulation?
EBoln
At the moment, no, since there were no problems when using the core on Cyclone 5
AdzimZM_Intel
Can you give it a test?
So before this you're working on Cyclone V device and it's worked.
But now you try to implemented it in Arria V is it?
Do you create a new IP for the Arria V or you use the existing project?
EBoln
I copy qsys file with DDR3 controller from CycloneV project to ArriaV project, ofcourse i change FPGA type in qsys file
EBoln
And i try create new qsys with controller
AdzimZM_Intel
Thanks for clarifying about your project.
I guess there is no error during the IP generating process and compilation.
But since you're facing some issue with the Arria V device, can you use the example design to simulate your IP in the Arria V?
EBoln
I try to simulate... and all signals correct
AdzimZM_Intel
Great!
Can you check the connection between your IP and your design?
And compare it with the example design.
EBoln
I create new project with same qsys file with ddr3 controller
EBoln
I changed the core type to soft controller and keep track of mem_reset_n generation.
dataout[0] from ARRIAV_DDIO_OUT - mem_reset_n
pll_addr_cmd_clk - exist
DATAINHI and DATAINLO - 2'b11
ARESET - 1'b0(from ~reset_reg[14])
Why???
AdzimZM_Intel
Hi sir,
The signal tap tool cannot be used to get the signal from the mem_reset_n because the signal is the conduit between the memory and phy.
The signal tap can get the signal between user design and the memory controller.
In order to see the signal, you can do it by the simulation tool such Modelsim.
By simulation your design in the tool, you can trace the waveform of your signal.
By right you can see the interaction of the mem_reset_n signal.
Adzim
AdzimZM_Intel
Hi sir,
I hope you're doing great.
Do you still have further question on this case?
Adzim
EBoln
AdzimZM_Intel
Setting the case to closure.
