FPGA Intellectual Property
6669 Discussions
multiport Ethernet reference design
I can't find a reference design to show me how to connect a shared fifo to the triple speed Ethernet IP if i set it in multiport mode. Does anyone have a build that uses the multiport configuration with the shared fifo?
Also may I know if I can connect two sgmii signals from 2 FPGAs together( FPGA1_rx to FPGA2_tx and vice versa) without a phy inbetween? Any special requirements for these to work? I presume you could have loopbacked on the SGMII interface before so could work but not sure.
