FPGA Intellectual Property
Ankündigungen
6673 Diskussionen
(need help)3X3 Hardware Matrix Multiplier as QSYS custom component
Geehrter Beitragender II
1.928Aufrufe
Currently I was trying to make a custom component(e.g.Hardware matrix multiplier) in qsys using Avalon MM interface.
But I'm confused how to send two matrix into my component and to solve it and stuck on this problem for a long time.
Can anyone please give me any tutorial so that I can get a solution.
thanks a lot in advance.
4 Antworten
725Aufrufe
hi,
actually i have designed a 16 bit register as qsys custom component, but for matrix im not getting the way how to give matrix A and matrix B as input. i have used avalon mm slave interface, with which i only can give one writedata input.
here Im confused how to use this only input for my matrix calculation though my matrix need two inputs.
please help me....
725Aufrufe
If you use an "address" signal on your Avalon MM slave interface, then you can create several registers to hold all your values.
725Aufrufe
--- Quote Start ---
--- Quote End ---
hi Daixiwen ,
sorry ! I didn't understand what you mean to say. Can you please explain the procedure little bit.
725Aufrufe
I suggest that you read the Avalon memory mapped specification here to understand what the different signals do: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf
Antworten
