FPGA Intellectual Property
6673 Discussions
problem with reed salomon simulation quartus 13.1
i'm trying to simulate this core, but i have a problem
when i driven a correct codeword to reed salamon ip decoder (attach jpg file) everthing is ok, 0 numerr and so on without fail signal asserted
when i just replace 1 symbol i got fail signal assert + numer = 16. how it could be possible?
i attached also my core configuration.
another thing is.
i generate also the encoder core and when i put the pattern
0x01 0x02 0x03 0x4.........0x8d
i got the correct 32 bytes of parity.
0x6d 0x8d 0x89 0x21 0x88 0x4d 0x6b 0x210x2e 0x3c 0xd6 0x8e 0x68 0x54 0x72 0x31 0x52 0xbd 0x9e 0xf7 0x45 0xf5 0x70 0x20 0x60 0xc4 0xe2 0xec 0x0b 0xef 0x18 0x1a
when i use the decoder core with the pattern
0x01 0x02 0x03 0x3.........0xd8 0x6d 0x8d 0x89 0x21 0x88 0x4d 0x6b 0x210x2e 0x3c 0xd6 0x8e 0x68 0x54 0x72 0x31 0x52 0xbd 0x9e 0xf7 0x45 0xf5 0x70 0x20 0x60 0xc4 0xe2 0xec 0x0b 0xef 0x18 0x1a
with 1 wrong symbol i got
number of error : 16 with defail signal asserted
someone can help please?
thanks
--- Quote Start ---
--- Quote End ---
