FPGA Intellectual Property
6670 Diskussionen
ref_clk in IP compiler for PCI Express
Geehrter Beitragender II
1.425Aufrufe
Please help me,
I am planning to use IP compiler for PCI Express Mega function to create my PCIE hard IP, in that whether i can use a PLL generated (using megafunction) 125MHz ref_clk or i need to use a direct clock from FPGA pin. I am having an input clock of 200MHz, so i am planning to use PLL to generate 125MHz or 100MHz and give it to clk_ref pin of "IP compiler for PCI Express Mega function" is it correct?
dil
1 Antworten
486Aufrufe
The recomended way is directly feed the refclk pin from FPGA pin. For PCIe core, the refclk should directly source from refclk of PCIe edge connector.
Antworten
