FPGA Intellectual Property
6673 Discussions
the Parameters of CVO with BT.656 format
HI,everybody
Here is a problem about CVO.I'm trying to connect CVO with SAA7121 encoder(BT.656 PAL).But it does't work Normally,looks like Synchronization problems.
The list following gives parameters what I use.The CLK of CVO is 27Mhz from SAA7113 's LLC PIN.Quartus 10.0
Please checking and give me a hand. Thanks a lot!
Image Data Format
image width 720 pixels
image height 576 pixels
bits per pixel per color plane 8 bit
number od color planes 3
color plane transission format s sequence|
interlaced video yes
Syncs Configuration
syncs signals embedded in video
active picture line 23
ancillary packet insertion line 8 (not sure,what's mean?)
Embedded Syncs Only -Field 1
horizontal blanking 144 pixel
vertical blanking 24 lines (not sure)
Interlaced and Field 0 Paramenters
F rising edge line 313
F falling edge line 1
vertical blanking rising line 311
ancillary packet insertion line 321
Embedded Syncs Only -Field 0
vertical blanking 25 lines
Gerneral Paramenters
pixel fifo size 720 pixels
fifo level at which to startoutput 719 pixels
Just use the default PAL,change "Bits per pixel per color plane" to 8.Beause 4:2:2 format has 2 planes,type 3 is incorrect.
