HI,everybody
Here is a problem about CVO.I'm trying to connect CVO with SAA7121 encoder(BT.656 PAL).But it does't work Normally,looks like Synchronization problems. The list following gives parameters what I use.The CLK of CVO is 27Mhz from SAA7113 's LLC PIN.Quartus 10.0 Please checking and give me a hand. Thanks a lot! Image Data Format image width 720 pixels image height 576 pixels bits per pixel per color plane 8 bit number od color planes 3 color plane transission format s sequence| interlaced video yes Syncs Configuration syncs signals embedded in video active picture line 23 ancillary packet insertion line 8 (not sure,what's mean?) Embedded Syncs Only -Field 1 horizontal blanking 144 pixel vertical blanking 24 lines (not sure) Interlaced and Field 0 Paramenters F rising edge line 313 F falling edge line 1 vertical blanking rising line 311 ancillary packet insertion line 321 Embedded Syncs Only -Field 0 vertical blanking 25 lines Gerneral Paramenters pixel fifo size 720 pixels fifo level at which to startoutput 719 pixelsLink Copied
Just use the default PAL,change "Bits per pixel per color plane" to 8.Beause 4:2:2 format has 2 planes,type 3 is incorrect.
