FPGA Intellectual Property
6670 讨论
to use altlvds,how I can use LVDS bit clock and LVDS frame clock of ADC at the same t
名誉分销商 II
6,497 次查看
In my board, there are 5AGXFB3H4F40C5N and TI ADS5294.
The ADS5294 is a 80-MSPS 8-Channel ADC,The digital data from each channel ADC is output over two wires of LVDS output lines depending on the ADC sampling rate.The transmission signals between ADS5294 and FPGA are mainly LVDS bit clock ,LVDS frame clock and sampling data lines.
The ADC sampling rate is 80MSPS,
data rate of each data line is 560MSPS,
the frequency of LVDS bit clock is 280MHZ(DDR timing),
the frequency of LVDS frame clock is 40MHZ.
I want to receive sampling data with altlvds ip in FPGA, however,the altlvds ip only supply one clock input port.
My problem is ,to use altlvds,how I can use LVDS bit clock and LVDS frame clock of ADC at the same time ?
0 项奖励
19 回复数
名誉分销商 II
3,431 次查看
You can only use one clock to clock in the data. My original thought was to use the bit clock to capture the data and the frame signal, and then use the frame signal to word-align the incoming data. The problem is that the frame clock is shifted from the data, so if the capture clock is lined up at the best possible time to capture the data, it is the worst possible time to capture the frame.
Could you ignore the bit clock and just use the frame clock to capture the data? I think the parallel data will come out word aligned. (Does altlvds support x7 deserialization? I don't remember, but that may be an issue)
0 项奖励
名誉分销商 II
3,431 次查看
Thanks, the altlvds support X7 deserialization, we can set the deserialization factor from 1 to 10 in altlvds ip.
My problem is, if only use bit clock in altlvds ip, we can convert the serial data into parallel data, but MSB of each frame data beginning from random bit.
If I use frame clock as altlvds clock input port, the some bits of converted parallel data is error.
Except for altlvds ip, could I use other ip to convert my serial data ?For example, the DDIO_IN ip?
0 项奖励
名誉分销商 II
3,431 次查看
I do not believe the DDIO will close timing at those speeds. altlvds uses a lot of dedicated hardware to make timing closure easier.
If you use frame clock, why are some of the parallel data bits an error? I missed that.
If using the bit clock, I've seen some ADCs that can send a fixed pattern that you can use to calibrate on in logic. A bit of a pain to do though. Capturing the frame transitions and then just shifting the parallel data to align the word would be the easiest.
What about creating two altlvds blocks with external PLL, one to capture the data and one to capture the frame bit. Then have a single external PLL drive both. I think a PLL can drive two altlvds blocks. (Throw something down quickly and make sure it fits before really making sure the clocks are correct and what-not).
0 项奖励
名誉分销商 II
3,431 次查看
The frame line is just a 9th data line that sends a constant value. If you're doing x14 deserialization, then it sends "1111111_0000000." But it looks like x14 is not an option, so you're going to be doing x7. That means the frame data is going to alternate between "1111111" and "0000000".
If you're already using an 8-channel altlvds megafunction, just change it to 9 channel. You also need to select options so that you have the rx_channel_data_align port on the altlvds. This port allows you at ask the altlvds block to change where the word boundary is in the serial stream. Every pulse on this port moves the word boundary by one stream.
The final piece is to write a fairly simple state machine to pulse rx_channel_data_align until you see the frame channel coming out of the lvds block as "1111111" or "0000000." The bit-slip operation applies to all 9 data channels, so once you have the frame pattern aligned, your other 8 data lines are also word aligned.
In summary, the frame "clock" is really just another data line with a known word being transmitted. You can use that knowledge to find the correct word boundary in the serial stream on the other 8 data lines.
Also note, that the frame word also tells you whether you are getting the high 7-bits or low 7-bits. It is "1111111" for one and "0000000" for the other.
0 项奖励
名誉分销商 II
3,431 次查看
Another straightforward way is to use the frame clock as input to the LVDS PLL and generate the bit clock internally.
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
--- Quote End ---
Thanks for you answer, hendryjh. I'm confused about how to frame clock and bit clock, too.
I have some questions about how to set altlvds_rx ip, could you help me?
1, When I choose internal PLL for altlvds_rx, do I need to connect lvds bit clock from A/D converter to the FPGA?
2, In the following sentence, "The final piece is to write a fairly simple state machine to pulse rx_channel_data_align", what does "pulse" mean? Keep rx_channel_data_align to 1 all the time?
3, About "The frame line is just a 9th data line", I can't find it in the Altera's user guide, could you give me some references?
Thanks in advance.
0 项奖励
名誉分销商 II
3,431 次查看
"2, In the following sentence, "The final piece is to write a fairly simple state machine to pulse rx_channel_data_align", what does "pulse" mean? Keep rx_channel_data_align to 1 all the time?"
Pulse here mean a high and low signal instead holding the signal at high always. In other words, in your control, you assert it for certain clock cycle and then de-assert it.
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
--- Quote End ---
Not necessarily, if you use the frame clock as PLL input clock and multiply it to half the bit rate. I implemented many different LVDS ADC interfaces this way, with 12, 14 and 16 bit width. The phase of the internal generated bit and frame clock can be adjusted for maximal sampling window margin.
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
--- Quote End ---
Thanks for your answer, bfkstimchan.
First, I assert rx_channel_data_align, after I receive the right data, I should de-assert the rx_channel_data_align, is my understanding correct?
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
--- Quote End ---
Thanks, FvM.
If I don't use the frame clock as PLL input clock, but use FPGA's clock as the PLL input clock, can I get the correct data from the A/D converter?
zhangfeng
0 项奖励
名誉分销商 II
3,431 次查看
Hi zhangfeng,
For the rx_channel_data_align, you should pulse it then check for right data. If right, then stop pulsing. If wrong, then do another pulse. You might need to pulse it a few times until you get the right data.
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
Hi zhangfeng,
--- Quote End ---
Thank you very much, tiny007.
If the number of channels is 4, should I pulse the bits of rx_channel_data_align[3:0] separately, or set all the bits at the same time(for example, rx_channel_data_align[3:0] = 4'b1111, then set rx_channel_data_align[3:0] = 4'b0000)?
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
--- Quote End ---
Hi zhangfeng (http://www.alteraforum.com/forum/member.php?u=55909).
You should pulse the bits of rx_channel_data_align[3:0] separately. Different channels may have different shift.
Andrei
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
--- Quote End ---
You must work with frame clock or bit clock of A/D converter. FPGA's clock and ADC's clock are asynchronous you will have wrong data reception.
Andrei
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
Andrei
--- Quote End ---
Thanks, Andrei.
Yesterday, I tried pulsing all the bits of rx_channel_data_align[3:0] at the same time like following:
In the test bench, I use a while loop to check the output of LVDS frame clock, if the result is 8'hf0, then stop pulsing; if the result is not 8'hf0, then pulsing all the bits of rx_channel_data_align[3:0] at the same time.
And this method worked.
Tomorrow, I'll try pulsing rx_channel_data_align[3:0] separately, and check the output is right or not.
zhangfeng
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
Andrei
--- Quote End ---
Thanks again, Andrei.
I'll use bit clock as the the input clock of ALTLVDS_RX's internal PLL, and use frame clock to decide whether to pulse rx_channel_data_align or not.
zhangfeng
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
--- Quote End ---
If phase difference between clock and data is same for all channels (ADC lines) this method works. This is true for ModelSim. In real may be situation when different shift is required for all channels. If you use this method you cannot align all channels correctly.
Andrei
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
Andrei
--- Quote End ---
Thank you so much, Andrei.
Now I know I should pulse rx_channel_data_align[3:0] separately.
zhangfeng
0 项奖励
名誉分销商 II
3,431 次查看
--- Quote Start ---
--- Quote End ---
This post is very useful for me.
In my case, i want use a FPGA to receive several ADCs (octal channels), for example each side receive 3 ADCs by using EP4S230KF40C2. Question is that there are only 2 left-right-PLL for each side. So i need use external PLL mode for this application. It seems i should use "LVDS interface with Use External PLL Option Enabled" mode. Is there any issue by using one PLL for those 3 LVDS streaming?
PS: The attached image is found in Linear Tech's AN paperhttp://www.alteraforum.com/forum/attachment.php?attachmentid=12277&stc=1
0 项奖励
回复
