FPGA Intellectual Property
6669 Discussions
transceiver toolkit example design for stratix10 GX
Yossi1
I am looking for a transceiver toolkit example design for stratix10 GX,
Can't fine one that actually works.
paveetirrasrie_Intel
Hi Yossi Alden,
Transceiver toolkit is a debug tool in a Quartus. It doesn't have any design example. You may refer to E-Tile Transceiver PHY UG to know more about the usage of transceiver toolkit.
https://www.intel.com/content/www/us/en/docs/programmable/683723/current/debugging-e-tile-transceiver-links.html
Pavee
Yossi1
Hi Pavee,
As you probably know, you must load your design in the TTK. TTK is a debugging tool to control the transceivers parameters.
 Intel s10 evb should have an example design witch can be interface into TTL.
Yossi
Hi Yossi,
I have found transceiver toolkit design examples for S10. Here's the link: https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-examples/horizontal/on-chip-debugging.html
Hope this helps or kindly do let me know if you needed further support.
Pavee
Hi Yossi Alden,
Hope the link helps. Kindly do let me know if needed further support.
Pavee
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Otherwise, the community users will continue to help you on this thread.
Thank you.
