FPGA Intellectual Property
6673 Discussions
uart ip: can't get rx data
I generated an uart core from qsys and made a simulation with modelsim.
I instantiated two uart (one as transmitter and one as receiver); I connected the "uart_0_external_connection_txd" pin of the transmitter to the "uart_0_external_connection_rxd" pin of the receiver.
The uart transmitter seems work properly but I can't get the signal "uart_0_s1_dataavailable=1" from the receiver uart and the rxdata register is always 0.
Do you have any suggestion?
Thank for your help
Do you have a pull up resister configured in your receiver?
Hi Galfonz,
thank you for your reply.
I'm using the uart core for simulation purpose in modelsim. I don't think I can put a pull up resistor for simulation. How can I do that?
