FPGA Intellectual Property
.vho to verilog
AGU
There is a .vho file generated from the file tap_top.v. The file tap_top is used for simulating the HARD IP SEU (Single Event Upset).
In a previous project a .vho is available which is different from the tap_top.v versions that I can find. Unfortunately, it seems very complicated to understand the .vho file.
Actually I need some verilog or vhdl for a new simulation.
Is there a way to turn back the .vho file to a verilog file, see attachment. Where can I find the according tap_top.v file?
Thanks a lot!
JohnT_Intel
Unfortunately there is no way to convert vho back to verilog file as the the vho file is generated from Quartus during compilation.
You may refer to https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/reference/glossary/def_vho.htm for more information
AGU
Hi John,
thank you for the answer.
Is there a tap_top with the following entity?
ENTITY tap_top IS
PORT (
tdo_pad_o : OUT std_logic;
tdo_padoe_o : OUT std_logic;
shift_dr_o : OUT std_logic;
pause_dr_o : OUT std_logic;
update_dr_o : OUT std_logic;
capture_dr_o : OUT std_logic;
crc_select_o : OUT std_logic;
crc_err : OUT std_logic;
fpga_err : OUT std_logic;
dr_reg2_ext : OUT std_logic_vector(31 DOWNTO 0);
rst : IN std_logic;
tms_pad_i : IN std_logic;
tck_pad_i : IN std_logic;
trst_pad_i : IN std_logic;
tdi_pad_i : IN std_logic;
crc_test_active : IN std_logic;
crc_test_active_n : IN std_logic
END tap_top;
JohnT_Intel
