FPGA Intellectual Property
6669 Discussions
what preset to select to instantiate an Arria10 EMIF example for DDR4 - MT40A512M16 (Micron)
JET60200
Dear Expert,
WE made an ARRIA-10 FPGA board, and use 4 pieces of Micron " MT40A512M16" on-the-board.  The DDR4 datasheet says its spec should be as below:
- – Configuration : 512 Megb x 16 / piece  ,
- Cycle timing    :  0.625ns @ CL = 22 (DDR4-3200)
- –  External PLL reference clock frequency is  133.333MHz
Firstly I need to generate an EMIF example design, by selecting a "PRESETs" from Platform designer right list of "PRESETs", as below picture.  But I don't know which one I should choose, coz there're many Filter Items in PRESET LIST.
So which one I should choose to create an EMIF exmaple design ?  Pls advise.
JET60200
I also attached DDR4 device datasheet, in case useful for other's double checking ,,
Please check datasheet if necessary, Thanks
yoichiK_intel
Hi
DDR4-3200AA CL22 Component 1CS 8Gb(512Mbx16) should be the right one.
