FPGA Intellectual Property
6670 Discussions
Any well to reduce ddr2 Uniphy resource usage
XQSHEN
It's too huge resource used by DDR2 UNIPHY IP.
Is there any special setting I can use to reduce it?
sstrell
Which device family/device are you using?  Is your concern power?  Lack of available resources to fit your design?
yoichiK_intel
Hi
In the Controller settings tab there is Efficiency parameter and there is some option could reduce the resource.
1. lower the command Queue Look-ahead depth.
2.  disable reordering option.
Just be aware the those option may make the controller to be less efficient.
