FPGA Intellectual Property
6665 Discussions
why it is recommended to connect EMIF in single column??
hb0001
What is the purpose or reason for the below mentioned comment
"Ensure that the pins of a single external memory interface reside within a single
I/O column"???
Deshi_Intel
HI,
You can refer to below EMIF user guide doc page 15 to learn more about IO column and IO bank architecture.
Basically single memory interface is formed by using IO pins from adjacent IO_bank within one IO_column only
You can't use IO pins from different IO_column due to architecture wise IO_column is independent entity.
  • There is no physical connection to link IO pins from different IO_column together
I hope I clear your doubt now
dlim
Deshi_Intel
HI,
I don't hear back from you after my feedback explanation.
Hopefully I clear your doubt.
For now, I am setting this case to closure.
dlim
