6478 Discussions
AGIB027R31C2E2V Pin Assignments
NewUser1234
I've inherited a Agilex-7 Model AGIB027R31C2E2V
I just want to write a trivial code to see if it works.  Where can I find the pin assignments?
sstrell
Do you mean this is a dev kit?  Create a design in Quartus and use the Pin Planner from the Assignments menu to set this up.  To know what pins connect to what, there should be kit user guide assuming this is a dev kit: https://www.intel.com/content/www/us/en/products/details/fpga/development-kits.html
AqidAyman_Intel
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
AqidAyman_Intel
With the answer provided previously, may I know if you need more clarification/support on this question?
Aqid
