I am trying to instantiate Cyclone V hard processor in platform designer, but I am getting this error:
Error: new.hps_0: list element in quotes followed by ":" instead of space
while executing
"llength $db"
("if" test expression)
invoked from within
"if {[llength $db] != $PASSED_LIST_SIZE} {
return 0
(procedure "::pin_mux_db::load" line 26)
invoked from within
"::pin_mux_db::load $device"
invoked from within
"set load_rc [::pin_mux_db::load $device]"
(procedure "ensure_pin_muxing_data" line 20)
invoked from within
"ensure_pin_muxing_data $device_family"
(procedure "validate" line 4)
invoked from within
"validate"
(procedure "compose_logicalview" line
invoked from within
Could someone please let me know why is this?
When and where exactly are you seeing this? Is the target device for your project an SoC device?
I am using DE1 SoC board, when I am trying to add The hard-core processor, it shows this error
Can you confirm that your target device is an SoC variant? If the target device is not set correctly, you won't be able to add the HPS IP.
yes, the board is an SoC variant, DE1-SoC Board
Can you provide the screenshot of this error? Where exactly did this error reported in Quartus/Platform Designer?
Do you have any update?
Can you check my previous respond?
Could you give me the design, I would like to replicate from my side.
Are are you able to replicate the same error again on any new "dummy" design every time? Which other Quartus version are you seeing the error?
I am just checking, do you have update from your side?
Please check your license or try using Quartus lite version or try create a new project.
Alternatively, you may use the GHRD for your design to try:
https://www.rocketboards.org/foswiki/Documentation/CycloneVSoCGSRD
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
