Hello all.
Is it possible to connect Cyclone V SX SoC Development Board to PC using PCIe? The board have female PCIe connector, and Reference Manual tell about it: --- Quote Start --- To use the PCI Express interface with the Cyclone V SoC device in end-point mode, for example, with a cable plugged into a PC, you must remove resistors R253, R254, R249, and R251, and install R250 and R252. This resistor change will route the clock from the PC directly into the Cyclone V SoC device. You can use a PCI Express gen1x4 cable from Samtec (HDR-172378-02-PCIEC) for this connection. --- Quote End --- But I can't find that cable anywhere. Does such cables really exists?Link Copied
