Hi, I am using Cyclone 10GX in one of my design. When I started testing my board, JTAG was not functioning properly. I could program Cyclone10 through JTAG at 1MHz but not beyond that.
I tried different pull up values for TMS & TDI (10K, 4.7K & 1K) but the response is same in all cases. Even at 1 MHz, I couldn’t program Micron Flash device.
I checked back my layout & below are the net lengths in the PCB.
JTAG_TCK: 3.3 inch
JTAG_TD0: 2.9 inch
JTAG_TMS: 2.7 inch
JTAG_TDI: 2.8 inch
I believe 0.5 inch trace length difference should not create any issues at 24 MHz JTAG speed.
I have attached my Schematics page. Please let me know if you have any suggestions for this issue.
Bhagavath
- « Previous
- 1
- 2
- Next »
Dear Anand,
I tried this but status is same.
Bhagavath
I don't know if your problem is resolved but i read somewhere (i don't remember the document) that in fast mode (MSEL = 010) density need to be > 256Mb OR > 512Mb.
Perahps that can help you.
Thanks for your reply. I just changed the Flash with a new device & it started working.
Bhagavath
Actually it started working in first board when I removed 10K pullup from D0 & D1 lines of configuration Flash.
- « Previous
- 1
- 2
- Next »
