6472 Discussions
Cyclone-V GT FPGA board cannot work
Sancy
We purchased  one Cyclone-V GT FPGA board and found it cannot work now. The board heats heavily when powers up, I want to know what we can do next.
The product info is as follows:
S/N: 5CPCIe00002360
MAC: 0007ED250a37
AR_A_Intel
Hi Sir
Welcome to INTEL forum. We can help you with board return and repair (RMA). Could you provide the following for warranty checking before RMA process?
Name:
Email Address:
Company/University Name:
Dev kit OPN :
Serial Number : 5CPCIe00002360
A copy of invoice that shows time and date of purchase. You can reply/attach your file in private message.
AR_A_Intel
Hi Sir
Name:
Email Address:
Dev kit OPN :
Sancy
Hi AabdRahman,
Thanks for your reply,please find the info below:
Email Address: yangjun2@goodix.com
Company/University Name: Shanghai Chuansi Electronic Technology Co., Ltd
Dev kit OPN : DK-DEV-5CGTD9N
Sancy
Please find the copy of the invoice attached. The purchase time is 10/23, however, we received the FPGA board by the end of November.
Sancy
Any updates on this issue? Looking forward to your reply soon.
Sancy
Can you help check whether my Cyclone-V FPGA board is under warranty? What we can do next? Thanks
Sancy
Dear Intel Support,
I have found the express information of the FPGA board, the invoicing time with our agent Shanghai Chuansi Electronic Technology Co., Ltd is on 10/23, however the actual date we received the FPGA board from our agent is 11/30, so the warranty time should start from 11/30. In this case, our fpga board is still in valid warrenty. Could you please give us the steps regarding how to start the RMA process, thanks very much. We are very urgent to send you the board for repairing.
AR_A_Intel
Hi Sir
Thanks for your patience. Done checking with customer service team, your device is still in warranty. We will proceed with RMA proses. Before proceeding with dev kit RMA, Intel requires details information for RMA (Failure Analysis) request. The failure description you provided is too general to understand the actual failure behavior at your site. Intel requires details information. Please help to answer questions below in order for us to better understand your position.
1. What is the failure symptom? Please elaborate the failure symptom in detail. Provide picture if any.
2. When did the failure happen? How you discover the failure?
3. How did you determine the failure? Please elaborate the procedures you take.
4. Does the failure unit ever working before failure?
5. Did you swap the failure board with a known good board?
Sancy
Dear Intel Support,
Thanks for your quick reply. Please find my anwsers to the questions below. Looking forward to your comments. Many thanks.
The symptom is that after power on, the temperature under the main chip is abnormally high, the onboard blaster downloader can not be recognized, we can not operate the FPGA board.
About one month ago (2021/1/15), when we used the FPGA board as normally as usual, after restarting the power supply of the board, it was found that the blaster downloader could not be used. After the FPGA board was powered on for a period of time and then be powered off. The temperature of a certain area on the back of the FPGA was detected abnormally high.
After power on, the temperature under the main chip is abnormally high, the onboard blaster downloader can not be recognized, we can not operate the FPGA board.
Yes, it can work normally before failure.
Yes, after wap a good FPGA board, we can run our FPGA code normally.
AR_A_Intel
Hi
Thanks for your explanation. You mention that ‘temperature of a certain area on the back of the FPGA was detected abnormally high’. May we know, how you measure the temperature under the main chip? Could you provide step and picture of your checking method.
Sancy
Dear Intel Support,
Thanks for your reply, after we found that the onboard blaster downloader can not be recognized and we can not operate the FPGA board, we tried to analyze what happened on the FPGA board, when we hovered our hands above the main chip, we felt the heat blows up heavily.  Actually, we did not use thermometer to test the temperature, it is just from our physical feeling.
AR_A_Intel
Hi
Thanks. From your visual inspection, are they any defect or burn at the board and around the main chip.
Sancy
Dear Intel Support,
From my visual inspection, we did not see any defect or burn at the board and around the main chip. I attched a picture for your reference.
Sancy
Any Updates on this issue? Looking forward to your comments soon.
AR_A_Intel
Hello
Thanks for your update. Please give me some time to check and open RMA request ticket.
AR_A_Intel
Hello Sir
Thanks for your update and patience. We have opened a ticket regarding you issue. Contact local authorized Intel Distributors near you to request RMA together with the following information. Distributor link https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
a) Development Kit S/N : 5CPCIe00002360
b) IPS No. 00593897
c) The debugging steps done:
Cyclone-V GT FPGA Development Kit: power error
Customer request RMA.
Debug done:
Customer been working with the Cyclone-V GT FPGA Development Kit about one month ago (2021/1/15) normally as usual. After restarting the power supply of the board today, it was found that the blaster downloader could not be used. After the FPGA board was powered on for a period of time and then the powered off. The temperature of a certain area on the back of the FPGA was detected abnormally high.
Customer retest the onboard blaster downloader and cannot be recognized, they cannot operate the FPGA board by right it can work normally before failure.
Step verifies:
•           After swap a good FPGA board, they can run the FPGA code normally. Visual inspection done-No problem found.
We can’t replicate the issue with our board. We recommended for RMA as the board is working before failure.
Sancy
Dear Intel Support,
Thanks very much for your updates. I want to know usually after the RMA request is applied for, how long can I expect the local authorized Intel Distributors near to contact me and start the RMA process.
AR_A_Intel
Hi
Based on my understanding, it will take about 2~3 working day. You Could also contact them for an update.
Sancy
Dear Intel Support,
According to the distributor list that you shared with us, can you tell me which one can provide the RMA service or assign one to me directly, I have tried to contact serveral of them, however, none of them can provide the RMA service.
AR_A_Intel
Hi
You can request RMA form distributor you bought the dev.kit before. From list, you could get Arrow Asia Pac Ltd., Digi-Key, Macnica Cytech Ltd and Mouser Electronics.
Provide them the:
b) IPS No. 00593897
AR_A_Intel
We have not heard from you and I hope that my last note clears up this matter. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
