5938 Discussions
DDR4 HILO in S10MX failed initialization
XNguy4
I am using the qts_hilo_ddr4_x72_1066MHz sample project to test the DDR4 HILO in the Stratix 10 MX development kit. I didn't change anything, except upgrading the project from Quartus 18.1 to Quartus 19.4.
After downloading the SOF file in the board, I used SignalTap to observe the signals and realized that DDR4 HILO controller module always returned local_cal_fail = 1.
Please find the sample project attached and let me know how I can fix the issues.
Thank you very much,
NurAida_A_Intel
Thank you for joining this Intel Community.
When you run project from Quartus 18.1, do you facing similar issue?
Can you please check on the PLL signal? I suspect the PLL loses lock and this will assert the reset signal until the PLL is locked. The reset signal need to de-assert in order for the controller being enable. Kindly, please check on this two signals.
At the meantime, I will recommend you go through the calibration checklist. See if there any item that list in calibration checklist is suspect as the failure’s root cause.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/devices/cfg-index/calibration-checklist.html
Hope this helps. Let me know your feedback.
Aida
NurAida_A_Intel
Also please allow me sometime to look into the design and see if I can duplicate the issue from my side. I'll keep ypu updated.
XNguy4
Thank you for your quick reply.
I also built the sample project in Quartus Pro 18.1 and got the same problem.
I'm not sure which PLL signal you mentioned as I didn't change anything in the sample project.
You can see the reset_n = 1 with local_reset_done = 1 in the SignalTap
Also, no timing violation was reported in TimeQuest.
Please let me know how I can fix it.
XNguy4
Hi Aida,
I wonder if you have time to look into the DDR4 HILO problem.
s10M
Hello @XNguy4 ,
I am running into a similar problem with my new devkit.
I was wondering if you managed to solve the problem?
Thanks a lot. Your help is much appreciated!
XNguy4
I couldn't solve the problem.
So I gave up this board and move to Xilinx instead.
