6413 Discussions
DE2-115 Programming: No hardware detected
i have 3 Developement boards. With the first 2 i don't have problems to program. Since i adoped the project from a collaborator witch announced, i don't know if he did something i don't know to activate the programmer. Now, if i try to program the 3rd board, the programmer doesn't detect the hardware, although all is the same (i think):
- Same board
- Same Hardware Settings (All jumpers the same position, board is powered, USB cable connected, Switch on Run: here i don't know exactly why it isn't on Prog, but the other boards can be programmed with a jic file)
- Same PC (Win 7 Pro 64) Of coarse the driver is the same.
Has any one an idea?
Hi there,
Could you first check if Altera USB-Blaster is detected properly ? You can check this in Quartus Programmer or the device manager from your PC.
I'm also a bit confused about the file format and the type of programming method you mentioned, despite all the settings are the same on these 3 DE2-115 boards. Is the RUN/PROG switched to RUN or PROG to program .jic, .sof, or .pof ?
David from Terasic
Hi David,
thank you for your response. Fortunately i could now program the new board, unfortunately i don't know why... I asume, that i made something wrong while programming but i didn't recognize any differences.
So far so good.
As I said, my predecessor implemented the hole configuration. I now have a manual how to: generate qsys, revert (from svw) compile VHDL, generate bsp, revert, compile program since there are some changes from normal generations.
Anyway, after converting i get a .jic file witch i can program to the board. The switch can be set on Run if i do this. I know that this isn't the straigt way you describe in the manuals. But i am not an microelectronic specialist only concerning on the firmware. (If i get no problems) We are searching a specialist in FPGA but until now we were not successful.
Thank you anyway,
Thomas
