6473 Discussions
DECA Kit Lab 8 MIPI Camera Working?
I am working with the Max 10 DECA Kit, and am working on Lab 8 from the Wiki.
When I compile the completed project, start the code on the fpga, and use the System console to start the tcl script, I get an screen that is totally aquamarine green. I can see no influence from the camera.
I've tried resizing the TPG image and turning off the TPG image with master_write_32 $nm $frm1 0, but there is absolutely no reaction on the monitor.
Do you have any advice to how I can confirm the Image Sensor is working?
Confirm the tcl commands are working?
Any other advice?
Thank you
Are the LED's ON or OFF? I suspect the Nios II software may not be running. The software configures the MIPI sensor to the proper resolution. Upon completion, the LED's are 7:4 = Lit, and 3:0 are off
you can email deca@arrow.com for additional DECA questions.
-Terry
